Hi Everybody, is it possible to install this on shared hosting? PHP + MySQL is that written in requirements.
Is this enough?
Is this enough?
You should be able to use shared hosting however some users have run into problems with security restrictions.
I installed this on local machine with Apache, and see only white screen.
Error is the next in Apache log: [Tue Apr 18 21:52:31 2017] [error] [client 127.0.0.1] PHP Parse error: syntax error, unexpected ‘$value’ (T_VARIABLE) in D:\Dropbox\Webroot\Invoices\vendor\aws\aws-sdk-php\src\functions.php on line 36, referer: http://localhost/Invoices/
Are you using PHP >= 5.5.9
Ops, thanks, will try that version.
Thanks! It’s working! PFM!
Great to hear!
If you’re stuck we can offer a hosting solution that we know works as we have it running on our dedicated servers.
