Installation of v5 is giving v4
When I install this package - https://github.com/invoiceninja/invoiceninja/releases/download/v5.10.18/invoiceninja.tar
I have it installed on Ubuntu 22.04 per the instructions.
Once i login, Im getting this version
That’s not version 4. That is version 14.4 of the React web UI. If you click on Health Check, you should see listed at the bottom the API version. There it should list 5.10.18 or whatever version you’re using.
Yep. I just figured that out! Guess I’m just confused on how I get the dark theme
See below.
