Are there any instructions on how to do this? The page on Github doesn’t make much sense to a relative noob Thanks
- Install composer
- Run
composer init
- Run
composer require invoiceninja/sdk-php
I am getting this error on the last step:
The package name composer require invoiceninja/sdk-php is invalid, it should be lowercase and have a vendor name, a forward slash, and a package name, matching: [a-z0-9_.-]+/[a-z0-9_.-]+
Any advice on this. Thanks BTW, appreciate the hand holding
Ok, am past that but getting a 404 error when trying to connect
Have you set the API URL and token?
