Hiya,
Every time I launch the A5 app on my Mac, I have to drag the lower right corner to increase the size of the window because it’s annoyingly small. Is there a way to set the size so I don’t have to do this each time?
TIA,
Barton
Hiya,
TIA,
Barton
Thanks for the feedback!
I’m not sure but we’ll look into it to try to improve it.
I use the Mac v5 app and you are correct the window is to small when launched. there is a quick way to make it fill the screen, hold the option key, put the cursor on the left bottom corner of the window and double click.
That’s a good trick that I used to know!! Thanks for reminding me. And thanks for your reply.
But hopefully the developers will consider my feature request.
Thanks again.
Careful of that weather!
b
Thanks, that’s new to me as well. Very useful!
Once this issue is implemented by the framework we’re using we should be able to support it. If you have a GitHub account please consider giving the issue an upvote.
