Increase upload limit, tried every solution available, please help
Ok, I got it, php really isn’t my strongest side :slight_smile:
so order of reading the files matters, changing the name of the php file so it is last in the list when sorted by name fixed the issue with settings not applying.
I’ve tried uploading files over 8mb - and it worked. So solution #2.
Use Custom PHP.ini settings for docker - upload limits, timezone etc to add settings
in your custom INI file.
Glad to hear it’s finally working!
Hey, did you get it working, how can i help?
All good, figured it out. Thank you for inspiration :slight_smile:
