IMPORTANT: Footer missing after update
Version ie <v5.11.28>
Describe the bug
Since one of the last updates, the footer is no longer generated in the PDF.
01.01.2025: Footer OK
07.01.2025: Footer missing
Unfortunately, I can no longer trace which version was installed on 01.01.2025, but I always keep the system up to date very promptly.
Screenshots
It may help to add DISABLE_PURIFY_HTML=true to the .env file
Sorry, but not helpful:
I suggest asking in a discussion on GitHub
Done: IMPORTANT: Footer missing after update · Issue #10574 · invoiceninja/invoiceninja · GitHub
