Hi there!
Just wanted to ask if there is any way to import recurring expenses in IN. If there is no direct way via CSV-File, is there an alternative way to import them?
Thanks!
Hi there!
Thanks!
This isn’t supported in the app but should be possible using the API.
Okay, thank you for the answer! Have a great day!
