Is it at all possible to import quotes or recurring invoices?
It isn’t supported directly in the app but it should be possible with a tool like Zapier.
Hmm any pointers on where I could start with zap?
You’d probably want to use a Google spreadsheet as the source and connect it to a CreateQuote action.
Indeed that would be one way of going about with it - trigger create quote on create row on google spreadsheet. Our ninja is not exposed so zapier is out of the question but this might help someone else in the future.
I figured we can actually import all the quotes via our API.
As always thx for the support Hillel.
Correct, you could use the API or SDK.
Happy to help!
