Hello, I just installed Invoice Ninja V5 on a new server and I wanted to ask if it’s possible for me to merge my old SQL dump from Invoice Ninja V4 into the V5 DB or if I should take other steps.
Thanks in advance for any assistance,
Charles
Charles
You’ll want to use the migration tool in the latest v4 on Settings > Account Management to migrate your data.
If your v4 install is old I suggest creating a new v4 install, copying over your database and .env file and then migrating from there.
Hello, thanks for the reply. I’ll try that.
