I have 2 custom fields on the client area. One is a date, and another one is a single line text. They are NOT importing. I even changed the format of the date on the csv to match the formatting on Invoice Ninja but they will not import.
Also another question…
There are regular fields for a client that WILL NOT appear on the mapping. For example I have on my sheet a phone for the store/client and another for phone 2, which is usually the mobile phone of the contact. You can only bring 1 phone and is for the contact. Why is that? How could I bring both phones?
No, the data is not coming at all to the database. It’s nowhere to be found. Also, check this. I entered those 2 custom fields for a customer to see if they actually show up on the database. They do BUT, if you try to use the edit button on the calendar (for a date), this is what happens:
even though if you enter it directly to the field with the proper format, doesn’t give the error.
About the phones, I can ONLY import 1 of the numbers, because there’s only 1 appearing on my mapping, and that’s the CONTACT’S PHONE.
So all your custom fields come just fine?
All your dates come in fine? (specially if being custom fields)?
You can import the phone for the company? (it won’t come up on mapping for me?)
After selecting it looks like it’s the same, but they aren’t. That’s why I posted an image with the selection opened so you can see that they are 2 different fields.
