Import from Freshbook Failed with no specific error
App\Jobs\Import\CSVIngest … RUNNING
172.18.0.1 - - [22/Jan/2024:16:07:50 +0000] “GET / HTTP/1.1” 302 2047 “-” “Mozilla (CloudronHealth)”
2024-01-22 16:07:50 App\Jobs\Product\UpdateOrCreateProduct … RUNNING
2024-01-22 16:07:50 App\Jobs\Product\UpdateOrCreateProduct … 118.82ms DONE
2024-01-22 16:08:46 App\Jobs\Product\UpdateOrCreateProduct … 244.38ms DONE
2024-01-22 16:08:46 App\Jobs\Ledger\ClientLedgerBalanceUpdate … RUNNING
2024-01-22 16:08:46 App\Jobs\Ledger\ClientLedgerBalanceUpdate 128.53ms DONE
2024-01-22 16:08:47 App\Jobs\Import\CSVIngest … 1 min FAIL
sometimes i received an email sometimes not, on less than 200 invoices only 59, when i split the invoice csv in 5 chunk. setup is made via cloudron. latest version installed. 1GB avail to the docker. files are less than 250ko
i split the import in multiple files with the equivalent of 5 invoices each and i import all the files successfully. So there is a problem with the bigger file for sur.
Problem solved
Glad to hear it’s working, thanks for sharing your solution!
