Is there a future release or current workaround whereby I could import approx 1000 items to my library. It would take weeks doing it one by one?
Cheers
Cheers
You could consider adding them directly to the products table. If you decide to do this (assuming you only have a single account in the system) make sure the public_id field matches the id field.
We’ll add this in a future release, you cant track it here: https://trello.com/c/ttjenm7y
Thanks Hillel
I’ll give that a try first thing tomorrow
Cheers
