See my bullet points where design did not fit.
the big problem is if you have a 2 pages invoice there is no design at page 2 and you see at point 3 it overlaps with footer.
Who can help.
kindly
aadursun
Who can help.
kindly
aadursun
What version of Invoice Ninja are you using? That looks like a old design, we float the footer in the latest version.
he is using the latest version of IN. You are right, it’s based on an old design. I adjusted it for IN v4 and it worked fine so far. Now it’s looks like an CSS / HTML challenge . I saw in the last “Modern” template the floating looks better and the footer will moved to the next page. @aadursun, so we have to start to learn CSS hardcore coding. argh Or is there a design tutorial available for IN?
Greetings
Daniel
Edit: Go the tutorial >>> Free Source Available Invoicing, Expenses & Time-Tracking | Invoice Ninja
Happy to help out, you can start with a new clean design and work from there, let me know what changes you would like to see and i can make some suggestions.
We are planning a rewrite of this section of the app to make it easier.
