I moved my invoice ninja manually from one hosting provider to the next, I uploaded the files and created a new database with the new host, however since the move it seems that the dashboard is not working correctly and seems buggy in certain menus. Once example my company logo doesn’t display in the settings it has the default invoice ninja logo but on the actual invoice my logo displays. If I try doing and export I don’t get any email notifications as well to download the backup?
I am not sure where else to look or what to do to resolve it.
Any ideas or tips on what steps to take to resolve?
I did a complete backup of the entire folder I never did a new installation the only thing that changed was that I created a new database (new name and password) and imported the old data base into that newly created one.
"On our side it looks like you are using Invoice Ninja version 5.11.44 and from where the website was moved from they were using Invoice Ninja version 11.42.1 which is why the interface is different and has more options.
You would unfortunately need to manually upgrade the version of Invoice Ninja from version 5.11.44 to Invoice Ninja version 11.42.1
We would suggest that you contact the Invoice Ninja support team to find out how to upgrade the version of Invoice Ninja."
Let me know if this could be right and if so the steps to do the update manually?
I managed to resolve the logo issue. So another issue came about, if I try exporting invoices or try to do a backup I do not get any email notification to download the backup? I am not sure where to check but I suspect in the code that it is trying to use the old server details to authenticate I could be wrong but no notifications come through.
Attached is the system logs. Where would one check these settings? I checked the .env file I also did a fresh install on another subdomain and that installation works perfectly. If I can get the email notifications to work then I don’t mind exporting the client data and invoice data and importing it to the new install.
The new install as mentioned is working like a charm so if I can get the email notifications to work I can just use the new install and import the data from the download link (which I am not getting).
