I accidentally canceled an invoice. how can i undo this?
gtz Jos
gtz Jos
I think one option may be to delete it and then recreate it?
@david is that correct/is there another solution?
If I delete it, what will happen with the invoice number? Can I use it again then?
Correct, the app should adjust the invoice number to make it available.
