Dear All, i want to ask , how to return a numeric value for variable $total or $amount i want to use it in Custom Gateway … if i use variable $total will shown : Rp7,500,000.00 i want use only 7500000
how to get numeric value in this case…
thank you Sri Darwanto
Sorry, I don’t believe it’s supported in v4
We’ll keep this in mind for v5…
ok thank you,
i tried to use extracting string to number… but the script not work in Custom Gateway Text
Thanks Sri Darwanto
For security reasons JavaScript is disabled in the custom gateway
