Shouldn’t have to copy/paste each one manually. If you copy the entire list (including the headers) and paste that into Excel or OpenOffice, you can save it as a CSV file (set the text separator to " when it asks, btw), then import that CSV directly into InvoiceNinja.
Edit: Forget what I just said…I read your reply wrong and thought you were going to do each one individually, lol.
Now the possibility for export products is implemented, thank you.
But I’m wondering because with JSON I can’t export selected fields (only products).
Just possible to export ALL fields … or am I doing something wrong?
