Hello!
I like to show on invoice name field like:
Surname: Dow
Email: info@demo.it
etc
Hello!
Surname: Dow
Email: info@demo.it
etc
It’s possible but tricky, you’d need to use a custom design and then replace the field stacks (ie, $clientDetails) with the individual fields.
https://www.invoiceninja.com/forums/topic/new-invoice-template/#post-802
Note: instead of $client.nameValue you can now use $client.name, ‘Value’ shouldn’t be needed any more.
just for this little custom?ouch… I hope will be more simple! thank you Hilell
If you get stuck I’m happy to help…
