Very recently started noticing that preview pane is displaying half of the text in Gibberish. This happens for both ‘View as Client’ and ‘Administration’ portals.
Which browser are you using?
Also, are you using the latest version (v3.2). It may help.
- Chrome: Version 57.0.2987.133 (64-bit)
- It’s hosted by Invoice Ninja and we are dependent on current version in production.
Can you check that PDF viewer is disabled here:
Live and PDF views both are checked (enabled).
Try disabling ‘PDF Viewer’, it will use the native viewer in Chrome which is more reliable.
And that fixes it!
Great to hear, we’ll work on clarifying what the option does.
