Host for A Record
What should the host be for the DNS A Record “*” or “@” ?
It depends is the answer, some DNS providers allow you to have a blank entry which references the domain, or @
you may also want to consider adding a www entry to catch www.domain.com
Okay thanks, the following A record has been added to our DNS for our domain:
Host: @
Points to: 96.126.107.105
These are the instructions from the section under Settings>Client Portal -
Create a DNS A Record entry for your custom domain and point to the following IP address 96.126.107.105.
Once this is setup please send an email to contact@invoiceninja.com and we’ll complete the process.
Hi, I just want to check that you’re using the hosted version.
A records are not required if you’re using our self host version.
