High bandwidth consumption
Is it normal for invoice ninja to be using 50gb+ of server bandwidth per month? I access it from two different computer only.
Not sure… if you keep the app running it will ping the server every 5 minutes to check for updates, I wouldn’t expect it to use that much data though. You may want to try changing to the React app.
