As per attached Picture,
I have tried to increase memory limit up to 4G or 4096M it still shows the warning, is it an error?
It could be an error, which version of the app are you using?
latest version 5.7.11,
Is there any CLI command that i can run to get proper info as why this error occured?
I think it may be a bug in the health check, we’ll look into it
I see the problem, it will be fixed in the next release.
A little bit an update, interestingly, I open it this morning, and everything is okey, there isnt any warning sign anymore. I wonder what was that about.
Same bug here with v5.7.11-C124
This should be fixed in v5.7.12
