I am now running 5.5.41 which does generate PDFs properly. In this version when I open in the same browser and toggle the console to ON the Live Preview doesn’t load, same behaviour as before, this must be seperate to the change in 5.5.41 → 5.5.42 that is causing PDFs to not generate.
Though I don’t think the Live PDF Preview not running when the console is enabled is much of a problem as I normally use the Invoice Ninja App and not via Web Browser. And if running in the Web Browser it would be not common to have the console open I would think.
I am running self hosted on a local computer and am using the default PDF Generator, I just checked my env file and it’s ‘snappdf’.
Did you have an update on this by any chance? I just updated to 5.5.71 to see if anything had changed. In the macOS App when I press ‘View PDF’ I get this error:
SocketException: Failed host lookup: ‘in5.test’ (OS Error: nodename nor servname provided, or not known, errno = 8)
The App URL worked fine in V5.5.41, after that it’s broken. Just running on a local network in a Docker Container. Am I doing something wrong with the App URL?
the app looks like it is configured for a different URL
main.foss.dart.js?v=5.5.74:94006
GET http://in5.test:8000/client/invoice/YwIwA3wqKuKJLlwyg4f9IabN8b7sahyi/download?t=1677138984758&t=1677138984758 net::ERR_NAME_NOT_RESOLVED
I’ve figured out the issue. The only place ‘in5.test:8000’ appears anywhere is Invoice Ninja → Settings → Client Portal → Domain URL. So I changed the value there to ‘http://192.168.0.142:8000’ which is identical to the ‘APP_URL’ in the env file.
I wasn’t aware that I was using the Client Portal. I’ve now updated to the latest version and the PDF Generation is working when I select ‘View PDF’. Weird that it worked with the old values on V5.5.4.1, something must have changed.
Ok this makes sense. We implemented the client portal override in between those two releases that allows users to select the domain their serve their client portal from.
