Hi, a working self hosted server started giving me the following error, which I am struggling with;
[2017-05-16 14:54:16] production.ERROR: ErrorException: Use of undefined constant T_DOUBLE_COLON - assumed ‘T_DOUBLE_COLON’ in /config/www/ninja/vendor/nikic/php-parser/lib/PhpParser/Lexer.php:255
Any help would be much appreciated.
Thanks in advance.
Stack trace: #0 /config/www/ninja/vendor/nikic/php-parser/lib/PhpParser/Lexer.php(255): Illuminate\Foundation\Bootstrap\HandleExceptions->handleError(8, ‘Use of undefine…’, ‘/config/www/nin…’, 255, Array) #1 /config/www/ninja/vendor/nikic/php-parser/lib/PhpParser/Lexer.php(32): PhpParser\Lexer->createTokenMap() #2 /config/www/ninja/vendor/nikic/php-parser/lib/PhpParser/Lexer/Emulative.php(27): PhpParser\Lexer->__construct(Array) #3 /config/www/ninja/vendor/nikic/php-parser/lib/PhpParser/ParserFactory.php(22): PhpParser\Lexer\Emulative->__construct() #4 /config/www/ninja/vendor/classpreloader/classpreloader/src/Factory.php(61): PhpParser\ParserFactory->create(1) #5 /config/www/ninja/vendor/classpreloader/classpreloader/src/Factory.php(44): ClassPreloader\Factory->getParser() #6 /config/www/ninja/vendor/laravel/framework/src/Illuminate/Foundation/Console/OptimizeCommand.php(77): ClassPreloader\Factory->create(Array) #7 /config/www/ninja/vendor/laravel/framework/src/Illuminate/Foundation/Console/OptimizeCommand.php(64): Illuminate\Foundation\Console\OptimizeCommand->compileClasses() #8 [internal function]: Illuminate\Foundation\Console\OptimizeCommand->fire() #9 /config/www/ninja/bootstrap/cache/compiled.php(1257): call_user_func_array(Array, Array) #10 /config/www/ninja/vendor/laravel/framework/src/Illuminate/Console/Command.php(169): Illuminate\Container\Container->call(Array) #11 /config/www/ninja/vendor/symfony/console/Command/Command.php(256): Illuminate\Console\Command->execute(Object(Symfony\Component\Console\Input\ArrayInput), Object(Symfony\Component\Console\Output\BufferedOutput)) #12 /config/www/ninja/vendor/laravel/framework/src/Illuminate/Console/Command.php(155): Symfony\Component\Console\Command\Command->run(Object(Symfony\Component\Console\Input\ArrayInput), Object(Symfony\Component\Console\Output\BufferedOutput)) #13 /config/www/ninja/vendor/symfony/console/Application.php(794): Illuminate\Console\Command->run(Object(Symfony\Component\Console\Input\ArrayInput), Object(Symfony\Component\Console\Output\BufferedOutput)) #14 /config/www/ninja/vendor/symfony/console/Application.php(186): Symfony\Component\Console\Application->doRunCommand(Object(Illuminate\Foundation\Console\OptimizeCommand),
