Hi -
There is a latinamerican gateway called PayU. Is it possible to include it on the gateways list?
Here is the developers link: http://developers.payulatam.com/en/index.html
Thank you…
Hi -
Thank you…
If you’re self hosting you may be able to follow these steps to add the gateway.
http://docs.invoiceninja.com/en/latest/configure.html#omnipay
Dear Hillel -
Thanks for your quick response. Unfortunately, I’m not a coder, so a more detail “do it your self” handbook is appreciated…
On the other hand, is it possible to have the gateway out of the box?
Thanks again and regards,
You can submit a request here to theDevelopers
https://github.com/invoiceninja/invoiceninja#third-party-developers
