I have found a bug where if I create an invoice with a discount, the gateway fee for stripe is also reduced by 20% at payment time (essentially giving the client an extra unanticipated discount and really messing up my accounting).
For example:
I created an invoice for $2750.00 and gave the client a discount of 20%, resulting in a total of $2200.00
when the client (or I) visit the portal, the gateway amount listed under the “Pay Now” button is “$63.80” exactly the amount expected on the total of $2200
HOWEVER, when the client continues to the payment form, the total at bottom button is now listed as $2251.04 instead of $2263.80, because you have applied a 20% discount to the gateway fee, which makes no sense.
Thanks for the quick reply and suggestion, but are you saying this is working as designed? Because this seems like a bug to me. The discount is already part of the total, why would we also apply it to the gateway fee? And why have a different gateway fee show on the invoice view of the portal than the one that shows on the actual payment button? I can send you screenshots if you like, but I am pretty sure this should not work this way.
And while I can hand calculate a discount and add it to a line myself, this kind of defeats the purpose of the discount box, no? And while I can do this for future invoices, I can’t for the ones that have already gone out very easily.
Invoice level discounts apply to all of the line items, we don’t have a way to exclude a single line item from the discount. Using line item discounts should solve the problem.
It works as designed, it’s more that the design doesn’t work very well in this case.
