[Feature Suggestion] Product Previews
Random thought I just had while adding some markdown to a bunch of product descriptions. Would it be possible to have Invoice Ninja show a preview of the product entry as you edit it, based on the layout settings you have chosen? Basically the same thing it already does with quotes/invoices, but this would let you see what a product description looks like with markup/formatting applied, so you can see where lines will wrap without having to go into the quote/invoice pages every time to check.
Thanks for the suggestion!
It’s definitely worth considering…
