The dashboard Data Boxes show all time data by default, compared with a user-selected timeframe. The all time data isn’t terribly useful to me, as several years worth of information isn’t something I ever need.
I’d love to be able to select both timeframes for comparison purposes, or even just for context (last 7 days vs year-to-date, etc).
Hm, that doesn’t seem to work for me, though I’m not sure if perhaps I’m misunderstanding
If I select “This Year” from the date range, I’ll get the current year’s totals to the right of the All Time totals. I’m looking for the capability to change the “All Time” totals (red arrows below) to a custom range.
If I’m misunderstanding what you meant, I’m sorry. I do have the first month of the year set to January.
Bizarre, sounds like I may need to change this into a support request.
I’ve tried un-setting and re-setting the first month, both to a null selection and to a month other than January. The numbers in blue will change appropriately when the month is a different month, but act as January when set to null. The numbers in black do not change, regardless of the selection.
Could there be something else I have set messing with this? Thank you for your support.
I’ve actually since switched from self-hosted to invoiceninja.com, and this is still the behavior.
I still can’t tell if there’s a setting somewhere I have misconfigured, but in Localization the first month of the year is set to January, yet I still see all time totals in Black.
