system
November 23, 2015, 1:31am
1
Hello!
I’ve just tried to update to 2.4.6 from 2.3.3 (iirc), I’m getting a couple of errors when i ry to load update page:
ErrorException in compiled.php line 6727:
array_merge(): Argument #2 is not an array
and
ReflectionException in compiled.php line 1068:
Class encrypter does not exist
I am open to suggestions.
Many thanks in advance,
Matthew.
November 23, 2015, 1:36am
The update process should now run on its own, however if you call it manually you shouldn’t see any errors.
Are you using the self-host zip or the code from GitHub?
system
November 23, 2015, 1:40am
3
Self-host, approx 25Mb download. I did the usual upload over a previous installation and try to run http://baseurl/update .
November 23, 2015, 2:02am
4
Try running composer dump-autoload and php artisan optimize to resolve the ‘class not found’ error.
system
November 23, 2015, 2:05am
5
I don’t currently have shell access - the joy of shared hosting. I’ll see what I can do. Would deleting everything and re-uploading a fresh copy (with the current .env) suffice?
November 23, 2015, 2:09am
6
Pretty much, if you erase the public/logo directory you’d need to re-upload your logo image file.
system
November 23, 2015, 2:14am
7
Thanks - I’ll give that a go and let you know. Hopefully, it’ll be AOK.
system
November 23, 2015, 2:44am
8
Awesome! That did the trick.
Thank you, once again, for the super rapid response!
November 23, 2015, 2:45am
9
Great to hear, thanks for letting us know.
