sven_r
1
3.0.2 not create PDF´s with local PhantomJSCloud in log
i found
production.ERROR: PhantomJSCloud - failed to create pdf: {“context”:“PHP”,“user_id”:0,“account_id”:0,“user_name”:"",“method”:“GET”,“url”:“https://blabla.bla”,“user_agent”:"",“ip”:“127.0.0.1”,“count”:1} []
Try changing line 1210 in app/Models/Invoice.php from
} catch (Exception $exception) {
to
} catch (\Exception $exception) {
And then try again and re-check the logs, there may be more details shown about the error.
https://github.com/invoiceninja/invoiceninja/blob/master/app/Models/Invoice.php#L1210
sven_r
3
Line 1210 is
Utils::logError("PhantomJSCloud - failed to create pdf: {$pdfString}");
4
The catch
line should be within a few lines.
sven_r
5
NO,
public function getPDFString()
if ( ! env('PHANTOMJS_CLOUD_KEY') && ! env('PHANTOMJS_BIN_PATH')) {
return false;
$invitation = $this->invitations[0];
$link = $invitation->getLink('view', true);
if (env('PHANTOMJS_BIN_PATH')) {
$pdfString = CurlUtils::phantom('GET', $link . '?phantomjs=true');
} elseif ($key = env('PHANTOMJS_CLOUD_KEY')) {
if (Utils::isNinjaDev()) {
$link = env('TEST_LINK');
$url = "http://api.phantomjscloud.com/api/browser/v2/{$key}/?request=%7Burl:%22{$link}?phantomjs=true%22,renderType:%22html%22%7D";
$pdfString = CurlUtils::get($url);
$pdfString = strip_tags($pdfString);
if ( ! $pdfString || strlen($pdfString) < 200) {
return false;
return Utils::decodePDF($pdfString);
* @param $invoiceItem
* @param $invoiceTotal
* @return float|int
6
Hmm… I guess the try/catch will be added in 3.0.3.
In that case try adding dd($response->getStatus());
at the end of app/Libraries/CurlUtils.php after $client->send().
If you haven’t already you may want to check that the value for PHANTOMJS_BIN_PATH works from the command line.
sven_r
7
you mean around line 57
public static function phantom($method, $url)
if ( ! $path = env('PHANTOMJS_BIN_PATH')) {
return false;
$client = Client::getInstance();
$client->getEngine()->setPath($path);
$request = $client->getMessageFactory()->createRequest($url, $method);
$response = $client->getMessageFactory()->createResponse();
// Send the request
$client->lsend($request, $response);
if ($response->getStatus() === 200) {
return $response->getContent();
} else {
//$response->getStatus();
return false;
8
Yup, it’d be helpful to know the status (assuming it isn’t 200).
