I am testing a hosted solution for a second office. I wanted to replicate my data, so I exported the JSON from my hosted and imported in my self-hosted. Everything seemed to import properly except:
No payments imported into self-hosted.
106 Expenses in Hosted shows 0 Expenses in Self-Hosted BUT
Recurring Expenses in Self Hosted has 42 of my 106 Expenses from the hosted and none of the 3 recurring expenses from hosted.
It seems the regular expenses from hosted got split into recurring expenses in self hosted.
Is this a known bug? I deleted all the data in self-hosted and reimported with the same issue.
ANy assistance here would be appreciated. thank you!
Your web server could potentially be stopping the import script as a result of your PHP’s max_execution_time.
Could you try changing the max_execution_time directive in your php.in file.
Also have a look at your upload_max_filesize and post_max_size directives as the web server could be stopping the import as a result of reaching the maximum uploaded file size. But it probably isn’t this as the web server should’ve rejected the upload from the start if this was the case.
I’m not too sure why expenses were getting split, are you running the same version of Invoice Ninja? Maybe try uploading a CSV file instead of a JSON?
Also are there any logs in the self-hosted logs directory?
I changed the max execution time to 60, and will create a second test site and try another import.
I doubt its the file size as you said, it didn’t reject.
I would try CSV, but the only method I see to export is the single Export option which is only JSON. Can you point me to a way to export all data as CSV?
Alternately, I wonder if the hosted admins can just do a sql dump and send me the file?
You could ask, but I think they would most likely just send you a CSV. The hosted variation of IN probably has custom tables that aren’t used in the self-hosted version.
@david I upgraded to .36 and did a new export from the hosted and imported into self-host. Recurrent Expenses imported, but none of the Expenses imported now.
@david I will check the log when I get home, but I did get an email that said:
There was an error importing the company data, the error message was:
The Import failed due to missing data in the import file. Resource recurring_expenses not available.
