Hi!,
I’m trying to get reports where clients have their tax identification, but I can’t do it,
Is possible? can tell me how please?
Thanks.
Hi!,
Thanks.
Are you using the client report, which field are you trying to add?
The field may be included if you use the CSV export or consider upgrading to v5.
Thanks.!
I think update to v5, my actualy version 4.2 is old.
Greetings.
