export invoices to pdf (not zip) in a shared host
hi, i want to know if there is a chance to export to pdf and not to zip, because my shared host dosent support GMP.
regards
Do you mean to merge the invoice PDFs into a single PDF? It isn’t supported.
No, i mean export the selected invoices into pdfs or other solution that dosent use zip function as im in a shared host and they dont have GMP for shared
Sorry, the library we use requires GMP.
https://github.com/barracudanetworks/ArchiveStream-php
Hi, i can download Single PDfs if i open them in Invoice Ninja. It would be nice if there is an option to download single uncompressed invoices from the overview with the button on the rigt. Thanks!
Ziping used to work in prior Invoice Ninja versions. Did you switch to GMP recently (this year)? My shared host doesn’t allow compiling.
I’m not aware of any changes, the library we use has always required GMP.
https://github.com/barracudanetworks/ArchiveStream-php#requirements
We’re constantly trying to limit the buttons/options in the app, maybe a solution would be to only zip the files if downloading more than 1 at a time.
Thanks, Hillen. I’ll check with my host, something must have changed on the server. It used to work last time i exported a couple of weeks ago.
"maybe a solution would be to only zip the files if downloading more than 1 at a time."
That would be perfect!
