Expenses with tax don't show tax in invoices
When I add an expense with tax to an invoice, it doesn’t show the “Tax” column in the product table. If I add a product with tax then the column is shown correctly, including the correct values for the expenses.
Expenses only:
Expenses + a product with tax:
Which app are you using?
Also, is the tax column included on Settings > Invoice Design?
Windows desktop app (flutter), and yes
Same invoice as above, when editing invoice design:
Do you see a difference in the React app?
No difference in the react app.
Now I have to go ssh into my database to put it back :frowning:
You may want to create an issue for this on GitHub
Done:
