Erros in the smartphone links
I have some problems with the app on the smartphone.
The phone number, with one click it copies the number, when press and hold it transfers to the message app and not to call… See the image below.
The address is the same, copies the address and when hold it transfers to a “Google Maps” integrated (I think), but it doesn’t work when I try to use the Google Maps app…
This is the page…
The default behavior is to send a message, not to place a call.
We’ll try to reproduce the maps problem.
I haven’t been able to reproduce the problem, the app should be loading this URL with the address added at the end: https://maps.google.com/?q=
Hi @hillel .
Thanks for the information.
Can we have somethin to chose? because I don’t think there’s a lot of people who uses the message system in theses days.
And, for the Google Maps link… this is the error I get :
Page Web non disponible
Impossible de charger la page Web intent://maps.app.goo.gl/?link=https://www.google.com/maps/dir//Av.%2Bdes%2BD%25C3%25A9sertes%2B24,%2B1009%2BPully/@46.5074123,6.6596173,17z/data%3D!4m6!4m5!1m0!1m2!1m1!1s0x478c2fa847399787:0x8a7ff7f99c462f9e!3e0?entry%3Dml&apn=com.google.android.apps.maps&amv=965100030&isi=585027354&ibi=com.google.Maps&ius=comgooglemapsurl&utm_campaign=ml_promo&ct=ml-dr-wv-msc&mt=8&pt=9008&efr=1#Intent;package=com.google.android.gms;scheme=https;S.browser_fallback_url=https://play.google.com/store/apps/details%3Fid%3Dcom.google.android.apps.maps&pcampaignid%3Dfdl_long&url%3Dhttps://www.google.com/maps/dir//Av.%252Bdes%252BD%2525C3%2525A9sertes%252B24,%252B1009%252BPully/@46.5074123,6.6596173,17z/data%253D!4m6!4m5!1m0!1m2!1m1!1s0x478c2fa847399787:0x8a7ff7f99c462f9e!3e0%3Fentry%253Dml&min_version%3D965100030;end; pour la raison suivante :
net::ERR_UNKNOWN_URL_SCHEME
Regards
Feel free to create an issue here:
Are you able to use this link in the browser to view an address?
https://maps.google.com/?q=>
The most annoying thing is Google opening links in YouTube even though it’s disabled. It just takes you to the Play store and not opening links in vanced. Any way to fix that.?
I’m not sure I understand, which links are opened in YouTube?
