Getting “Server Error” when attempting to update from v5.5.19. Laravel log below.
[2022-09-09 17:10:28] production.ERROR: file_get_contents(/usr/share/nginx/invoiceninja/vendor/beganovich/snappdf/versions/revision.txt): Failed to open stream: No such file or directory {“userId”:1,“exception”:"[object] (ErrorException(code: 0): file_get_contents(/usr/share/nginx/invoiceninja/vendor/beganovich/snappdf/versions/revision.txt): Failed to open stream: No such file or directory at /usr/share/nginx/invoiceninja/app/Http/Controllers/SelfUpdateController.php:178)
#0 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Bootstrap/HandleExceptions.php(257): Illuminate\Foundation\Bootstrap\HandleExceptions->handleError()
#1 [internal function]: Illuminate\Foundation\Bootstrap\HandleExceptions->Illuminate\Foundation\Bootstrap\{closure}()
#2 /usr/share/nginx/invoiceninja/app/Http/Controllers/SelfUpdateController.php(178): file_get_contents()
#3 /usr/share/nginx/invoiceninja/app/Http/Controllers/SelfUpdateController.php(137): App\Http\Controllers\SelfUpdateController->cleanOldSnapChromeBinaries()
#4 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Controller.php(54): App\Http\Controllers\SelfUpdateController->update()
#5 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/ControllerDispatcher.php(45): Illuminate\Routing\Controller->callAction()
#6 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Route.php(261): Illuminate\Routing\ControllerDispatcher->dispatch()
#7 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Route.php(204): Illuminate\Routing\Route->runController()
#8 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Router.php(725): Illuminate\Routing\Route->run()
#9 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(141): Illuminate\Routing\Router->Illuminate\Routing\{closure}()
#10 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Middleware/ThrottleRequests.php(126): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#11 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Middleware/ThrottleRequests.php(62): Illuminate\Routing\Middleware\ThrottleRequests->handleRequest()
#12 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\Routing\Middleware\ThrottleRequests->handle()
#13 /usr/share/nginx/invoiceninja/app/Http/Middleware/QueryLogging.php(39): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#14 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): App\Http\Middleware\QueryLogging->handle()
#15 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Middleware/SubstituteBindings.php(50): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#16 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\Routing\Middleware\SubstituteBindings->handle()
#17 /usr/share/nginx/invoiceninja/app/Http/Middleware/Locale.php(46): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#18 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): App\Http\Middleware\Locale->handle()
#19 /usr/share/nginx/invoiceninja/app/Http/Middleware/PasswordProtection.php(124): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#20 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): App\Http\Middleware\PasswordProtection->handle()
#21 /usr/share/nginx/invoiceninja/app/Http/Middleware/TokenAuth.php(96): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#22 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): App\Http\Middleware\TokenAuth->handle()
#23 /usr/share/nginx/invoiceninja/app/Http/Middleware/SetDb.php(40): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#24 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): App\Http\Middleware\SetDb->handle()
#25 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(116): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#26 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Router.php(726): Illuminate\Pipeline\Pipeline->then()
#27 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Router.php(703): Illuminate\Routing\Router->runRouteWithinStack()
#28 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Router.php(667): Illuminate\Routing\Router->runRoute()
#29 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Router.php(656): Illuminate\Routing\Router->dispatchToRoute()
#30 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(167): Illuminate\Routing\Router->dispatch()
#31 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(141): Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}()
#32 /usr/share/nginx/invoiceninja/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Http/SetRequestIpMiddleware.php(45): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#33 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Sentry\Laravel\Http\SetRequestIpMiddleware->handle()
#34 /usr/share/nginx/invoiceninja/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Http/SetRequestMiddleware.php(42): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#35 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Sentry\Laravel\Http\SetRequestMiddleware->handle()
#36 /usr/share/nginx/invoiceninja/vendor/livewire/livewire/src/DisableBrowserCache.php(19): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#37 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Livewire\DisableBrowserCache->handle()
#38 /usr/share/nginx/invoiceninja/app/Http/Middleware/Cors.php(25): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#39 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): App\Http\Middleware\Cors->handle()
#40 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Http/Middleware/TrustProxies.php(39): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#41 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\Http\Middleware\TrustProxies->handle()
#42 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#43 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ConvertEmptyStringsToNull.php(31): Illuminate\Foundation\Http\Middleware\TransformsRequest->handle()
#44 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\Foundation\Http\Middleware\ConvertEmptyStringsToNull->handle()
#45 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#46 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TrimStrings.php(40): Illuminate\Foundation\Http\Middleware\TransformsRequest->handle()
#47 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\Foundation\Http\Middleware\TrimStrings->handle()
#48 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ValidatePostSize.php(27): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#49 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\Foundation\Http\Middleware\ValidatePostSize->handle()
#50 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/PreventRequestsDuringMaintenance.php(86): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#51 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\Foundation\Http\Middleware\PreventRequestsDuringMaintenance->handle()
#52 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(116): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#53 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(142): Illuminate\Pipeline\Pipeline->then()
#54 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(111): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter()
#55 /usr/share/nginx/invoiceninja/public/index.php(57): Illuminate\Foundation\Http\Kernel->handle()
#56 {main}
