Ubuntu 16.04 with Nginx
InvoiceNinja version v3.1.0 (only to follow the guide). I also attempted with the most current version and received the same error.
Hillel,
Thank you for the response. I attempted that guide first, the Ubuntu and Nginx, however received a different error. I thought it may have something to do with the guide stating it was Ubuntu and Nginx, but down in step 6 configure Nginx it mentions Apache2 config file. I proceeded following the steps anyway and ran into errors. I did not take a screenshot of the error thinking that the guide may have been wrong so I searched for another guide. I am not well versed in Linux so I am highly reliant on the guide. I will try the guide again.
So I followed the original guide shown here. I get all the way through without any errors. When I go to navigate to the site, all I see is a nginx welcome page.
I made sure to update the nginx config file with my internal domain name and server name. i.e. invoice.example.comwww.invoice.example.com and when I nslooup my machine resolves to the correct ip.
I was finally able to get the site loaded.
I had to edit /etc/nginx/nginx.conf at the bottom “include /etc/nginx/sites-enabled/;" to "include /etc/nginx/sites-available/;”
I restarted nginx and then was able to load the setup page. Note: after entering db info and username and click submit, I got a timeout, however after waiting 5 minutes, the login page loaded and stated update completed. Now the site appears to be working.
I did refer back to the guide and ran the command at Step 7
sudo ln -s /etc/nginx/sites-available/invoiceninja /etc/nginx/sites-enabled/
but that did not seem to work.
Either way, site is now working, hope this helps someone else.
