Error when selecting multiple invoices and going to Actions > Email Invoice
TimeoutException after 0:00:30.000000: Future not completed
It looks like they are actually being sent, however. So i’m not sure what to do with this notice.
To avoid opening another issue, I will report my related experience here.
I also encountered this error (30s timeout), but in my case the emails are clearly not being sent. Also, in Email settings the attach PDF
was OFF by default and I never enabled it. Any thoughts on that?
Are there any errors in the logs?
Not sure I follow, I think the feature is disabled by default.
No errors in the laravel.log
file.
Yes, it’s disabled by default. And I never changed this setting.
Do you see this error if you send a single invoice?
I see this error upon the “Resend invitation” action for the new user.
BTW, should those emails be sent immediately or per the cron job setting? I set the cron to trigger once per hour
Maybe that’s the problem, the cron should be set to run every minute
https://invoiceninja.github.io/docs/self-host-installation/#cron-configuration
Even if that’s true, this is a “30 seconds timeout” error. Less than one minute.
Is there a reason you’re running the cron every hour rather than every minute?
@david do you have any thoughts to debug the problem
No reason. I didn’t understand the aforementioned part of the docs as a “must”, but more as an example. Besides, there’s not a single mentioning of 1 minute
repetition, but 5 minutes
and that’s for a case when one would set the QUEUE_CONNECTION=database
within the .env
file, but my setting is QUEUE_CONNECTION=sync
You will then need to update the QUEUE_CONNECTION variable in the .env file as follows:
If you are on shared hosting, it is possible to get the queues working by defining a new cron with the following configuration:
*/5 * * * * cd /path/to/root/folder && /usr/bin/php -d register_argc_argv=On artisan queue:work --stop-when-empty
This cron will start a queue worker every 5 minutes and run any jobs that are in the queue and then gracefully terminate itself. This means any emails / notification may be queued for a small period of time prior to executing. If this amount of delay is acceptable, it is a great way to get queue’s working on shared hosting.
Does the QUEUE_CONNECTION=sync
even work on a shared hosting?
All of the cron examples (excluding the last one) are * * * * *
The sync setting could explain the problem, have you tried database instead? With sync
the app waits for the process to complete whereas with database
the app can send the request and not wait for for the response.
I just made the following changes and it seems that one change (or perhaps all of them) did the trick:
→ QUEUE_CONNECTION=database
MAIL_PORT=465
→ MAIL_PORT=587
I added the two cron jobs exactly as per the docs below (every 1min. and 5min.):
Then ran php artisan optimize
and after another try, the emails start flowing.
Glad to hear it’s working!
I think there’s just one cron though, maybe it’s the same one running twice?
This one is running every 5 min:
the other one is running every minute:
php -d register_argc_argv=On artisan schedule:run
Should I keep only the first one?
Sorry for the confusion, I’m wrong. You have it correct.
