as you can see in this images http://imgur.com/a/8CeQk, the total amount in edit invoice form, and pfd invoice preview are diferent.
I think that the correct calculation is in edit invoice form.
Greetings
Greetings
I’m getting a 404 with the image link, can you please re-post it.
Check this
edit invoice form:
http://i.imgur.com/q8QV1kT.jpg
pdf invoice preview
http://i.imgur.com/MdemkGg.jpg
Thanks, I see the issue. We’re displaying the line total with taxes on the PDF.
I’ll make sure this is corrected in the next release.
yes, thats the problem…
thank a lot for your quick reply
Hi Hillel,
I register this like issue in Github
Regards
