Error on generated numbers
When i try to change the number patern i get an Error: Server 500
Koen
HI,
Hi Hillel,
Deleted the log first and tried again.
Nothing in the log…
Koen
If you see a 500 error there should be details in either the web server error log or in storage/logs
Sorry Hillel, can’t find anything…
None of my settings are saved…
Or i get error Server 500 or the popup:
Please save or cancel your changes.
Continue editing or discrad changes
v5.5.44-C102
How can i send you my lavarel.log?
Please post the relevant error here
[2022-12-01 15:56:33] production.ERROR: The command “‘/home/customer/www/ninja5.xxxxxxx.be/public_html/vendor/beganovich/snappdf/versions/1032348-Linux_x64/chrome-linux/chrome’ ‘–headless’ ‘–disable-gpu’ ‘–disable-translate’ ‘–disable-extensions’ ‘–disable-sync’ ‘–disable-background-networking’ ‘–disable-software-rasterizer’ ‘–disable-default-apps’ ‘–disable-dev-shm-usage’ ‘–safebrowsing-disable-auto-update’ ‘–run-all-compositor-stages-before-draw’ ‘–no-first-run’ ‘–no-margins’ ‘–no-sandbox’ ‘–print-to-pdf-no-header’ ‘–hide-scrollbars’ ‘–ignore-certificate-errors’ ‘–print-to-pdf=/tmp/pdf_YRYrqJ.pdf’ ‘/tmp/html_ndFiDJ.html’” failed.
Exit Code: 127(Command not found)
Working directory: /home/customer/www/ninja5.xxxxxxx.be/public_html/public
Output:
Error Output:
/home/customer/www/ninja5.xxxxxxx.be/public_html/vendor/beganovich/snappdf/versions/1032348-Linux_x64/chrome-linux/chrome: error while loading shared libraries: libgbm.so.1: cannot open shared object file: No such file or directory
{“userId”:1,“exception”:"[object] (Symfony\Component\Process\Exception\ProcessFailedException(code: 0): The command "‘/home/customer/www/ninja5.xxxxxxx.be/public_html/vendor/beganovich/snappdf/versions/1032348-Linux_x64/chrome-linux/chrome’ ‘–headless’ ‘–disable-gpu’ ‘–disable-translate’ ‘–disable-extensions’ ‘–disable-sync’ ‘–disable-background-networking’ ‘–disable-software-rasterizer’ ‘–disable-default-apps’ ‘–disable-dev-shm-usage’ ‘–safebrowsing-disable-auto-update’ ‘–run-all-compositor-stages-before-draw’ ‘–no-first-run’ ‘–no-margins’ ‘–no-sandbox’ ‘–print-to-pdf-no-header’ ‘–hide-scrollbars’ ‘–ignore-certificate-errors’ ‘–print-to-pdf=/tmp/pdf_YRYrqJ.pdf’ ‘/tmp/html_ndFiDJ.html’" failed.
Output:
Error Output:
at /home/customer/www/ninja5.xxxxxxx.be/public_html/vendor/beganovich/snappdf/src/Snappdf.php:260)
#0 /home/customer/www/ninja5.xxxxxxx.be/public_html/app/Utils/Traits/Pdf/PdfMaker.php(44): Beganovich\Snappdf\Snappdf->generate()
#1 /home/customer/www/ninja5.xxxxxxx.be/public_html/app/Jobs/Util/PreviewPdf.php(50): App\Jobs\Util\PreviewPdf->makePdf(NULL, NULL, ‘handle()
#3 /home/customer/www/ninja5.xxxxxxx.be/public_html/vendor/laravel/framework/src/Illuminate/Routing/Controller.php(54): App\Http\Controllers\PreviewController->live(Object(App\Http\Requests\Preview\PreviewInvoiceRequest))
#4 /home/customer/www/ninja5.xxxxxxx.be/public_html/vendor/laravel/framework/src/Illuminate/Routing/ControllerDispatcher.php(43): Illuminate\Routing\Controller->callAction(‘live’, Array)
#5 /home/customer/www/ninja5.xxxxxxx.be/public_html/vendor/laravel/framework/src/Illuminate/Routing/Route.php(259): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(App\Http\Controllers\PreviewController), ‘live’)
#6 /home/customer/www/ninja5.xxxxxxx.be/public_html/vendor/laravel/framework/src/Illuminate/Routing/Route.php(205): Illuminate\Routing\Route->runController()
#7 /home/customer/www/ninja5.xxxxxxx.be/public_html/vendor/laravel/framework/src/Illuminate/Routing/Router.php(725): Illuminate\Routing\Route->run()
#8 /home/customer/www/ninja5.xxxxxxx.be/public_html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(141): Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request))
#9 /home/customer/www/ninja5.xxxxxxx.be/public_html/vendor/laravel/framework/src/Illuminate/Routing/Middleware/ThrottleRequests.php(126): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#10 /home/customer/www/ninja5.xxxxxxx.be/public_html/vendor/laravel/framework/src/Illuminate/Routing/Middleware/ThrottleRequests.php(57): Illuminate\Routing\Middleware\ThrottleRequests->handleRequest(Object(Illuminate\Http\Request), Object(Closure), Array)
#11 /home/customer/www/ninja5.xxxxxxx.be/public_html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\Routing\Middleware\ThrottleRequests->handle(Object(Illuminate\Http\Request), Object(Closure), ‘300’, ‘1’)
#12 /home/customer/www/ninja5.xxxxxxx.be/public_html/app/Http/Middleware/QueryLogging.php(39): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#13 /home/customer/www/ninja5.xxxxxxx.be/public_html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure))
#14 /home/customer/www/ninja5.xxxxxxx.be/public_html/vendor/laravel/framework/src/Illuminate/Routing/Middleware/SubstituteBindings.php(50): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#15 /home/customer/www/ninja5.xxxxxxx.be/public_html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\Routing\Middleware\SubstituteBindings->handle(Object(Illuminate\Http\Request), Object(Closure))
#16 /home/customer/www/ninja5.xxxxxxx.be/public_html/app/Http/Middleware/Locale.php(46): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#17 /home/customer/www/ninja5.xxxxxxx.be/public_html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): App\Http\Middleware\Locale->handle(Object(Illuminate\Http\Request), Object(Closure))
#18 /home/customer/www/ninja5.xxxxxxx.be/public_html/app/Http/Middleware/TokenAuth.php(96): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#19 /home/customer/www/ninja5.xxxxxxx.be/public_html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): App\Http\Middleware\TokenAuth->handle(Object(Illuminate\Http\Request), Object(Closure))
#20 /home/customer/www/ninja5.xxxxxxx.be/public_html/app/Http/Middleware/SetDb.php(40): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#21 /home/customer/www/ninja5.xxxxxxx.be/public_html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): App\Http\Middleware\SetDb->handle(Object(Illuminate\Http\Request), Object(Closure))
#22 /home/customer/www/ninja5.xxxxxxx.be/public_html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(116): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#23 /home/customer/www/ninja5.xxxxxxx.be/public_html/vendor/laravel/framework/src/Illuminate/Routing/Router.php(724): Illuminate\Pipeline\Pipeline->then(Object(Closure))
#24 /home/customer/www/ninja5.xxxxxxx.be/public_html/vendor/laravel/framework/src/Illuminate/Routing/Router.php(703): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request))
#25 /home/customer/www/ninja5.xxxxxxx.be/public_html/vendor/laravel/framework/src/Illuminate/Routing/Router.php(667): Illuminate\Routing\Router->runRoute(Object(Illuminate\Http\Request), Object(Illuminate\Routing\Route))
#26 /home/customer/www/ninja5.xxxxxxx.be/public_html/vendor/laravel/framework/src/Illuminate/Routing/Router.php(656): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request))
#27 /home/customer/www/ninja5.xxxxxxx.be/public_html/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(190): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request))
#28 /home/customer/www/ninja5.xxxxxxx.be/public_html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(141): Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request))
#29 /home/customer/www/ninja5.xxxxxxx.be/public_html/vendor/livewire/livewire/src/DisableBrowserCache.php(19): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#30 /home/customer/www/ninja5.xxxxxxx.be/public_html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Livewire\DisableBrowserCache->handle(Object(Illuminate\Http\Request), Object(Closure))
#31 /home/customer/www/ninja5.xxxxxxx.be/public_html/app/Http/Middleware/Cors.php(25): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#32 /home/customer/www/ninja5.xxxxxxx.be/public_html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): App\Http\Middleware\Cors->handle(Object(Illuminate\Http\Request), Object(Closure))
#33 /home/customer/www/ninja5.xxxxxxx.be/public_html/vendor/laravel/framework/src/Illuminate/Http/Middleware/TrustProxies.php(39): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#34 /home/customer/www/ninja5.xxxxxxx.be/public_html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\Http\Middleware\TrustProxies->handle(Object(Illuminate\Http\Request), Object(Closure))
#35 /home/customer/www/ninja5.xxxxxxx.be/public_html/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#36 /home/customer/www/ninja5.xxxxxxx.be/public_html/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ConvertEmptyStringsToNull.php(31): Illuminate\Foundation\Http\Middleware\TransformsRequest->handle(Object(Illuminate\Http\Request), Object(Closure))
#37 /home/customer/www/ninja5.xxxxxxx.be/public_html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\Foundation\Http\Middleware\ConvertEmptyStringsToNull->handle(Object(Illuminate\Http\Request), Object(Closure))
#38 /home/customer/www/ninja5.xxxxxxx.be/public_html/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#39 /home/customer/www/ninja5.xxxxxxx.be/public_html/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TrimStrings.php(40): Illuminate\Foundation\Http\Middleware\TransformsRequest->handle(Object(Illuminate\Http\Request), Object(Closure))
#40 /home/customer/www/ninja5.xxxxxxx.be/public_html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\Foundation\Http\Middleware\TrimStrings->handle(Object(Illuminate\Http\Request), Object(Closure))
#41 /home/customer/www/ninja5.xxxxxxx.be/public_html/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ValidatePostSize.php(27): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#42 /home/customer/www/ninja5.xxxxxxx.be/public_html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\Foundation\Http\Middleware\ValidatePostSize->handle(Object(Illuminate\Http\Request), Object(Closure))
#43 /home/customer/www/ninja5.xxxxxxx.be/public_html/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/PreventRequestsDuringMaintenance.php(86): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#44 /home/customer/www/ninja5.xxxxxxx.be/public_html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\Foundation\Http\Middleware\PreventRequestsDuringMaintenance->handle(Object(Illuminate\Http\Request), Object(Closure))
#45 /home/customer/www/ninja5.xxxxxxx.be/public_html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(116): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#46 /home/customer/www/ninja5.xxxxxxx.be/public_html/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(165): Illuminate\Pipeline\Pipeline->then(Object(Closure))
#47 /home/customer/www/ninja5.xxxxxxx.be/public_html/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(134): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request))
#48 /home/customer/www/ninja5.xxxxxxx.be/public_html/public/index.php(56): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request))
#49 {main}
[2022-12-01 15:56:59] production.ERROR: The command "’/home/customer/www/ninja5.xxxxxxx.be/public_html/vendor/beganovich/snappdf/versions/1032348-Linux_x64/chrome-linux/chrome’ ‘–headless’ ‘–disable-gpu’ ‘–disable-translate’ ‘–disable-extensions’ ‘–disable-sync’ ‘–disable-background-networking’ ‘–disable-software-rasterizer’ ‘–disable-default-apps’ ‘–disable-dev-shm-usage’ ‘–safebrowsing-disable-auto-update’ ‘–run-all-compositor-stages-before-draw’ ‘–no-first-run’ ‘–no-margins’ ‘–no-sandbox’ ‘–print-to-pdf-no-header’ ‘–hide-scrollbars’ ‘–ignore-certificate-errors’ ‘–print-to-pdf=/tmp/pdf_eHGPXr.pdf’ ‘/tmp/html_t7RbMo.html’" failed.
Output:
Error Output:
{“userId”:1,“exception”:"[object] (Symfony\Component\Process\Exception\ProcessFailedException(code: 0): The command "‘/home/customer/www/ninja5.xxxxxxx.be/public_html/vendor/beganovich/snappdf/versions/1032348-Linux_x64/chrome-linux/chrome’ ‘–headless’ ‘–disable-gpu’ ‘–disable-translate’ ‘–disable-extensions’ ‘–disable-sync’ ‘–disable-background-networking’ ‘–disable-software-rasterizer’ ‘–disable-default-apps’ ‘–disable-dev-shm-usage’ ‘–safebrowsing-disable-auto-update’ ‘–run-all-compositor-stages-before-draw’ ‘–no-first-run’ ‘–no-margins’ ‘–no-sandbox’ ‘–print-to-pdf-no-header’ ‘–hide-scrollbars’ ‘–ignore-certificate-errors’ ‘–print-to-pdf=/tmp/pdf_eHGPXr.pdf’ ‘/tmp/html_t7RbMo.html’" failed.
Output:
Error Output:
#1 /home/customer/www/ninja5.xxxxxxx.be/public_html/app/Jobs/Util/PreviewPdf.php(50): App\Jobs\Util\PreviewPdf->makePdf(NULL, NULL, 'handle()
#49 {main}
These errors look related to the PDF, are you seeing these errors get generated when saving the generated number settings?
No, only when i view an invoice… i don’t see the pdf preview anymore on the bottom.
I don’t get anything in the log when changing the generated numbers. Only the Error: Server 500 popup.
I have some problems with the pdf also, it’s in another ticket.
