Payments are happening normally via stripe, but the payment isn’t getting applied to the invoice.
I believe I found the problem.
The transaction reference is being saved with an “}” at the end, which causes the invoice to not recognize the payment.
The transaction references are getting saved correctly inside the database, so the problem is the the code/handler from the database
Can you please direct me to where to change it? I will be happy to change the code myself but I have not idea where it is.
Thank you
