Error in ninja :send-reminders after recent upgrade to v4.4.3
I am getting this error from the cron job:
Tue, 05 Jun 2018 19:45:17 +0000 Loading latest exchange rates...
In SendReminders.php line 210:
  Undefined property: stdClass::$rates
I tried clearing the cache (https://example.com/?clear_cache=true), rerunning composer install, php artisan optimize --force php artisan migrate, php artisan db:seed --class=UpdateSeeder . But the error still persists!
Thanks!
Amit
I’m not sure, that error usually means the app failed to load the exchange rates.
Have you set custom values for EXCHANGE_RATES_URL or EXCHANGE_RATES_BASE in the .env file?
I think I see the problem, it looks like the API we’re using to load the exchange rates now requires an API key.
https://api.fixer.io/latest
We’ll include a fix with our next release. Until then you can either sign up for an API key or comment out this line of code.
https://github.com/invoiceninja/invoiceninja/blob/master/app/Console/Commands/SendReminders.php#L75
Note: the reminders are being sent, this error is occurring afterwards.
That’s it! Commenting out that line fixes the error. I am not using any other currency, so I will keep that line commented until this is fixed.
Thanks a lot!
–Amit
