Error After Updating Self Hosted v5
I was experiencing a white screen on the Clients/Customers tab in the Windows App so I attempted to upgrade my self hosted v5 installation. I used softaculous for the upgrade and it seemed to be successful but after the upgrade I’m now getting this page.
Oops, something does not look right!
Make sure all requirements are satisfied.
With an X beside both zip & iconv.
Have you checked that the zip and iconv PHP extensions are enabled?
Turns out my hosting provider had these disabled. I asked them to enable the extensions and all seems to be working. Thank you for the quick response.
