Error 500 On Upgrade to v5.3.75
Hey guys,
I’m getting a 500 error after upgrading to v5.3.75. The instance was installed and upgraded through Softaculous, on a DirectAdmin server.
When trying to run php artisan migrate in the directory, I’m seeing the following error:
In Application.php line 745:
  Class 'Codedge\Updater\UpdaterServiceProvider' not found
And this is what I can see in the logs (storage/logs/laravel.log):
Really appreciate any help! Thanks :slight_smile:
Try clearing the contents of /bootstrap/cache. I think I had a similar issue that was due to cache.
Hah, that did it! Thank you!
@david Should cache clearing automatically be added as part of the upgrade routine? Had this issue happen a few times.
The system does try to clear the cache after an update
