Error 500 | cPanel v5 Installation
@carlosmendiola
Most likely a permissions issue, there will be more information in storage/logs/laravel.log
This is what I get
[2022-03-03 14:07:10] production.ERROR: file_get_contents(): https:// wrapper is disabled in the server configuration by allow_url_fopen=0 {“exception”:"[object] (ErrorException(code: 0): file_get_contents(): https:// wrapper is disabled in the server configuration by allow_url_fopen=0 at /home/*****/public_html/facturacion/app/Models/Presenters/CompanyPresenter.php:73)
I also get this other error (when I changed php confit because of error above)
[2022-03-03 14:12:53] production.ERROR: File not found at path: NC3ZxkYYll7mH97bz2aFhTECkfNxIMwG/4y52wphVClxmp5GqdYNBxWqucZUY697sMk6QzhF7/vUVpzzzW55OXXaUDbpvqmLTAAcDCiXlNobyi0g9m/invoices/2022-0005.pdf {“exception”:"[object] (Illuminate\Contracts\Filesystem\FileNotFoundException(code: 0): File not found at path: NC3ZxkYYll7mH97bz2aFhTECkfNxIMwG/4y52wphVClxmp5GqdYNBxWqucZUY697sMk6QzhF7/vUVpzzzW55OXXaUDbpvqmLTAAcDCiXlNobyi0g9m/invoices/2022-0005.pdf at /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/Filesystem/FilesystemAdapter.php:171)
You can check your permissions and ownerships with
find /path/to/invoiceninja/ \( ! -user www-data -o ! -perm -644 \) -ls
(The backslashes in front of the parentheses may or may not be necessary, depending on the shell you use.)
I’m getting this error (generating a 500 server error):
production.ERROR: Trait 'Awobaz\Compoships\Compoships' not found {"exception":"[object] (Symfony\\Component\\ErrorHandler\\Error\\FatalError(code: 0): Trait 'Awobaz\\Compoships\\Compoships' not found at /home/xxxx/public_html/facturacion/app/Models/Company.php:29)
#0 {main}
What can I do?
This is my company.php
<?php
 * Invoice Ninja (https://invoiceninja.com).
 * @link https://github.com/invoiceninja/invoiceninja source repository
 * @copyright Copyright (c) 2021. Invoice Ninja LLC (https://invoiceninja.com)
 * @license https://www.elastic.co/licensing/elastic-license
namespace App\Models;
use App\Models\Language;
use App\Models\Presenters\CompanyPresenter;
use App\Models\User;
use App\Services\Notification\NotificationService;
use App\Utils\Ninja;
use App\Utils\Traits\AppSetup;
use App\Utils\Traits\CompanySettingsSaver;
use App\Utils\Traits\MakesHash;
use App\Utils\Traits\ThrottlesEmail;
use Illuminate\Database\Eloquent\Relations\BelongsTo;
use Illuminate\Database\Eloquent\Relations\HasMany;
use Illuminate\Notifications\Notification;
use Illuminate\Support\Facades\Cache;
use Laracasts\Presenter\PresentableTrait;
class Company extends BaseModel
    use PresentableTrait;
    use MakesHash;
    use CompanySettingsSaver;
    use ThrottlesEmail;
    use AppSetup;
    use \Awobaz\Compoships\Compoships;
    const ENTITY_RECURRING_INVOICE = 'recurring_invoice';
    const ENTITY_CREDIT = 'credit';
    const ENTITY_QUOTE = 'quote';
    const ENTITY_TASK = 'task';
    const ENTITY_EXPENSE = 'expense';
    const ENTITY_PROJECT = 'project';
    const ENTITY_VENDOR = 'vendor';
    const ENTITY_TICKET = 'ticket';
    const ENTITY_PROPOSAL = 'proposal';
    const ENTITY_RECURRING_EXPENSE = 'recurring_expense';
    const ENTITY_RECURRING_TASK = 'task';
    const ENTITY_RECURRING_QUOTE = 'recurring_quote';
    protected $presenter = CompanyPresenter::class;
    protected $fillable = [
        'markdown_enabled',
        'calculate_expense_tax_by_amount',
        'invoice_expense_documents',
        'invoice_task_documents',
        'show_tasks_table',
        'mark_expenses_invoiceable',
        'mark_expenses_paid',
        'enabled_item_tax_rates',
        'fill_products',
        'industry_id',
        'subdomain',
        'size_id',
        'custom_fields',
        'enable_product_cost',
        'enable_product_quantity',
        'enabled_modules',
        'default_quantity',
        'enabled_tax_rates',
        'portal_mode',
        'portal_domain',
        'convert_products',
        'update_products',
        'custom_surcharge_taxes1',
        'custom_surcharge_taxes2',
        'custom_surcharge_taxes3',
        'custom_surcharge_taxes4',
        'show_product_details',
        'first_day_of_week',
        'first_month_of_year',
        'slack_webhook_url',
        'google_analytics_key',
        'client_can_register',
        'enable_shop_api',
        'invoice_task_timelog',
        'auto_start_tasks',
        'is_disabled',
        'default_task_is_date_based',
        'enable_product_discount',
        'expense_inclusive_taxes',
        'session_timeout',
        'oauth_password_required',
        'invoice_task_datelog',
        'default_password_timeout',
        'show_task_end_date',
        'use_comma_as_decimal_place',
        'report_include_drafts',
        'client_registration_fields',
        'convert_rate_to_client',
    protected $hidden = [
        'id',
        'db',
        'ip',
    protected $casts = [
        'country_id' => 'string',
        'custom_fields' => 'object',
        'settings' => 'object',
        'updated_at' => 'timestamp',
        'created_at' => 'timestamp',
        'deleted_at' => 'timestamp',
        'client_registration_fields' => 'array',
    protected $with = [
   //     'tokens'
    public static $modules = [
        self::ENTITY_RECURRING_INVOICE => 1,
        self::ENTITY_CREDIT => 2,
        self::ENTITY_QUOTE => 4,
        self::ENTITY_TASK => 8,
        self::ENTITY_EXPENSE => 16,
        self::ENTITY_PROJECT => 32,
        self::ENTITY_VENDOR => 64,
        self::ENTITY_TICKET => 128,
        self::ENTITY_PROPOSAL => 256,
        self::ENTITY_RECURRING_EXPENSE => 512,
        self::ENTITY_RECURRING_TASK => 1024,
        self::ENTITY_RECURRING_QUOTE => 2048,
    public function documents()
        return $this->morphMany(Document::class, 'documentable');
    public function all_documents()
        return $this->hasMany(Document::class);
    public function getEntityType()
        return self::class;
    public function ledger()
        return $this->hasMany(CompanyLedger::class);
    public function getCompanyIdAttribute()
        return $this->encodePrimaryKey($this->id);
    public function account()
        return $this->belongsTo(Account::class);
    public function client_contacts()
        return $this->hasMany(ClientContact::class)->withTrashed();
    public function users()
        return $this->hasManyThrough(User::class, CompanyUser::class, 'company_id', 'id', 'id', 'user_id')->withTrashed();
    public function expense_categories()
        return $this->hasMany(ExpenseCategory::class)->withTrashed();
    public function subscriptions()
        return $this->hasMany(Subscription::class)->withTrashed();
    public function task_statuses()
        return $this->hasMany(TaskStatus::class)->withTrashed();
    public function clients()
        return $this->hasMany(Client::class)->withTrashed();
     * @return HasMany
    public function tasks()
        return $this->hasMany(Task::class)->withTrashed();
    public function webhooks()
        return $this->hasMany(Webhook::class);
     * @return HasMany
    public function projects()
        return $this->hasMany(Project::class)->withTrashed();
     * @return HasMany
    public function vendors()
        return $this->hasMany(Vendor::class)->withTrashed();
    public function all_activities()
        return $this->hasMany(Activity::class);
    public function activities()
        return $this->hasMany(Activity::class)->orderBy('id', 'DESC')->take(50);
     * @return HasMany
    public function contacts()
        return $this->hasMany(ClientContact::class);
    public function groups()
        return $this->hasMany(GroupSetting::class);
     * @return HasMany
    public function invoices()
        return $this->hasMany(Invoice::class)->withTrashed();
     * @return HasMany
    public function recurring_invoices()
        return $this->hasMany(RecurringInvoice::class)->withTrashed();
     * @return HasMany
    public function recurring_expenses()
        return $this->hasMany(RecurringExpense::class)->withTrashed();
     * @return HasMany
    public function quotes()
        return $this->hasMany(Quote::class)->withTrashed();
     * @return HasMany
    public function credits()
        return $this->hasMany(Credit::class)->withTrashed();
     * @return HasMany
    public function company_gateways()
        return $this->hasMany(CompanyGateway::class)->withTrashed();
     * @return HasMany
    public function tax_rates()
        return $this->hasMany(TaxRate::class)->withTrashed();
     * @return HasMany
    public function products()
        return $this->hasMany(Product::class)->withTrashed();
     * @return BelongsTo
    public function country()
//        return $this->belongsTo(Country::class);
        return Country::find($this->settings->country_id);
    public function group_settings()
        return $this->hasMany(GroupSetting::class)->withTrashed();
    public function timezone()
        $timezones = Cache::get('timezones');
        if(!$timezones)
            $this->buildCache(true);
        return $timezones->filter(function ($item) {
            return $item->id == $this->settings->timezone_id;
        })->first();
        // return Timezone::find($this->settings->timezone_id);
    public function designs()
        return $this->hasMany(Design::class)->whereCompanyId($this->id)->orWhere('company_id', null);
    public function user_designs()
        return $this->hasMany(Design::class);
    public function payment_terms()
        return $this->hasMany(PaymentTerm::class)->whereCompanyId($this->id)->orWhere('company_id', null);
    public function user_payment_terms()
        return $this->hasMany(PaymentTerm::class);
     * @return BelongsTo
    public function language()
        $languages = Cache::get('languages');
        if(!$languages)
        return $languages->filter(function ($item) {
            return $item->id == $this->settings->language_id;
        })->first();
        // return Language::find($this->settings->language_id);
    public function getLocale()
        return isset($this->settings->language_id) && $this->language() ? $this->language()->locale : config('ninja.i18n.locale');
    public function getLogo() :?string
        return $this->settings->company_logo ?: null;
    public function locale()
        return $this->getLocale();
    public function getSetting($setting)
        if (property_exists($this->settings, $setting) != false) {
            return $this->settings->{$setting};
        return null;
    public function currency()
        $currencies = Cache::get('currencies');
        return $currencies->filter(function ($item) {
            return $item->id == $this->settings->currency_id;
        })->first();
     * @return BelongsTo
    public function industry()
        return $this->belongsTo(Industry::class);
     * @return BelongsTo
    public function payment_type()
        return $this->belongsTo(PaymentType::class);
     * @return mixed
    public function expenses()
        return $this->hasMany(Expense::class)->withTrashed();
     * @return mixed
    public function payments()
        return $this->hasMany(Payment::class)->withTrashed();
    public function tokens()
        return $this->hasMany(CompanyToken::class);
    public function client_gateway_tokens()
        return $this->hasMany(ClientGatewayToken::class);
    public function system_logs()
        return $this->hasMany(SystemLog::class)->orderBy('id', 'DESC')->take(100);
    public function system_log_relation()
        return $this->hasMany(SystemLog::class)->orderBy('id', 'DESC');
    public function tokens_hashed()
    public function company_users()
        return $this->hasMany(CompanyUser::class)->withTrashed();
    public function owner()
        return $this->company_users()->withTrashed()->where('is_owner', true)->first()->user;
        //return $this->company_users->where('is_owner', true)->first()->user;
    public function resolveRouteBinding($value, $field = null)
        return $this->where('id', $this->decodePrimaryKey($value))->firstOrFail();
    public function domain()
        if (Ninja::isHosted()) {
            if($this->portal_mode == 'domain' && strlen($this->portal_domain) > 3)
                return $this->portal_domain;
            return "https://{$this->subdomain}." . config('ninja.app_domain');
        return config('ninja.app_url');
    public function notification(Notification $notification)
        return new NotificationService($this, $notification);
    public function routeNotificationForSlack($notification)
        return $this->slack_webhook_url;
    public function file_path()
        return $this->company_key.'/';
    public function rBits()
        $user = $this->owner();
        $data = [];
        $data[] = $this->createRBit('business_name', 'user', ['business_name' => $this->present()->name()]);
        $data[] = $this->createRBit('industry_code', 'user', ['industry_detail' => $this->industry ? $this->industry->name : '']);
        $data[] = $this->createRBit('comment', 'partner_database', ['comment_text' => 'Logo image not present']);
        $data[] = $this->createRBit('business_description', 'user', ['business_description' => $this->present()->size()]);
        $data[] = $this->createRBit('person', 'user', ['name' => $user->present()->getFullName()]);
        $data[] = $this->createRBit('email', 'user', ['email' => $user->email]);
        $data[] = $this->createRBit('phone', 'user', ['phone' => $user->phone]);
        $data[] = $this->createRBit('website_uri', 'user', ['uri' => $this->settings->website]);
        $data[] = $this->createRBit('external_account', 'partner_database', ['is_partner_account' => 'yes', 'account_type' => 'Invoice Ninja', 'create_time' => time()]);
        return $data;
    private function createRBit($type, $source, $properties)
        $data = new \stdClass;
        $data->receive_time = time();
        $data->type = $type;
        $data->source = $source;
        $data->properties = new \stdClass;
        foreach ($properties as $key => $val) {
            $data->properties->$key = $val;
        return $data;
Please see this thread for more info:
https://forum2.invoiceninja.com/t/got-error-500-when-upgrading-from-v5-3-66-w77-to-v5-3-7x/10185/21
Deleted files from /boostrap/caches but same 500 error and same error message on logs…
It may help to copy over the latest selfhost zip
https://github.com/invoiceninja/invoiceninja/releases/download/v5.3.76/invoiceninja.zip
I just have to replace all files?
When replacing files I get on logs:
[2022-03-29 12:01:02] production.ERROR: Class 'Codedge\Updater\UpdaterServiceProvider' not found {"exception":"[object] (Error(code: 0): Class 'Codedge\\Updater\\UpdaterServiceProvider' not found at /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/Foundation/Application.php:745)
#0 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/Foundation/Application.php(679): Illuminate\\Foundation\\Application->resolveProvider('Codedge\\\\Updater...')
#1 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/Foundation/ProviderRepository.php(75): Illuminate\\Foundation\\Application->register('Codedge\\\\Updater...')
#2 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/Foundation/Application.php(659): Illuminate\\Foundation\\ProviderRepository->load(Array)
#3 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/Foundation/Bootstrap/RegisterProviders.php(17): Illuminate\\Foundation\\Application->registerConfiguredProviders()
#4 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/Foundation/Application.php(237): Illuminate\\Foundation\\Bootstrap\\RegisterProviders->bootstrap(Object(Illuminate\\Foundation\\Application))
#5 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(153): Illuminate\\Foundation\\Application->bootstrapWith(Array)
#6 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(137): Illuminate\\Foundation\\Http\\Kernel->bootstrap()
#7 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(111): Illuminate\\Foundation\\Http\\Kernel->sendRequestThroughRouter(Object(Illuminate\\Http\\Request))
#8 /home/carlosmendiola/public_html/facturacion/public/index.php(57): Illuminate\\Foundation\\Http\\Kernel->handle(Object(Illuminate\\Http\\Request))
#9 {main}
[2022-03-29 12:01:02] production.ERROR: Target class [translator] does not exist. (View: /home/carlosmendiola/public_html/facturacion/resources/views/errors/500.blade.php) {"exception":"[object] (Illuminate\\View\\ViewException(code: 0): Target class [translator] does not exist. (View: /home/carlosmendiola/public_html/facturacion/resources/views/errors/500.blade.php) at /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/Container/Container.php:879)
#0 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/View/Engines/PhpEngine.php(60): Illuminate\\View\\Engines\\CompilerEngine->handleViewException(Object(Illuminate\\Contracts\\Container\\BindingResolutionException), 1)
#1 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/View/Engines/CompilerEngine.php(61): Illuminate\\View\\Engines\\PhpEngine->evaluatePath('/home/carlosmen...', Array)
#2 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/View/View.php(139): Illuminate\\View\\Engines\\CompilerEngine->get('/home/carlosmen...', Array)
#3 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/View/View.php(122): Illuminate\\View\\View->getContents()
#4 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/View/View.php(91): Illuminate\\View\\View->renderContents()
#5 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/Http/Response.php(69): Illuminate\\View\\View->render()
#6 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/Http/Response.php(35): Illuminate\\Http\\Response->setContent(Object(Illuminate\\View\\View))
#7 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/Routing/ResponseFactory.php(55): Illuminate\\Http\\Response->__construct(Object(Illuminate\\View\\View), 500, Array)
#8 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/Routing/ResponseFactory.php(85): Illuminate\\Routing\\ResponseFactory->make(Object(Illuminate\\View\\View), 500, Array)
#9 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/Foundation/Exceptions/Handler.php(585): Illuminate\\Routing\\ResponseFactory->view('errors::500', Array, 500, Array)
#10 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/Foundation/Exceptions/Handler.php(490): Illuminate\\Foundation\\Exceptions\\Handler->renderHttpException(Object(Symfony\\Component\\HttpKernel\\Exception\\HttpException))
#11 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/Foundation/Exceptions/Handler.php(356): Illuminate\\Foundation\\Exceptions\\Handler->prepareResponse(Object(Illuminate\\Http\\Request), Object(Symfony\\Component\\HttpKernel\\Exception\\HttpException))
#12 /home/carlosmendiola/public_html/facturacion/app/Exceptions/Handler.php(207): Illuminate\\Foundation\\Exceptions\\Handler->render(Object(Illuminate\\Http\\Request), Object(Error))
#13 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(427): App\\Exceptions\\Handler->render(Object(Illuminate\\Http\\Request), Object(Error))
#14 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(115): Illuminate\\Foundation\\Http\\Kernel->renderException(Object(Illuminate\\Http\\Request), Object(Error))
#15 /home/carlosmendiola/public_html/facturacion/public/index.php(57): Illuminate\\Foundation\\Http\\Kernel->handle(Object(Illuminate\\Http\\Request))
#16 {main}
[previous exception] [object] (Illuminate\\Contracts\\Container\\BindingResolutionException(code: 0): Target class [translator] does not exist. at /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/Container/Container.php:879)
#0 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/Container/Container.php(758): Illuminate\\Container\\Container->build('translator')
#1 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/Foundation/Application.php(851): Illuminate\\Container\\Container->resolve('translator', Array, true)
#2 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/Container/Container.php(694): Illuminate\\Foundation\\Application->resolve('translator', Array)
#3 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/Foundation/Application.php(836): Illuminate\\Container\\Container->make('translator', Array)
#4 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/Foundation/helpers.php(119): Illuminate\\Foundation\\Application->make('translator', Array)
#5 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/Foundation/helpers.php(835): app('translator')
#6 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/Foundation/helpers.php(870): trans('Server Error', Array, NULL)
#7 /home/carlosmendiola/public_html/facturacion/storage/framework/views/7972fc35c34c342be6e51c48b6ccc04a0f0fc3a8.php(1): __('Server Error')
#8 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/Filesystem/Filesystem.php(107): require('/home/carlosmen...')
#9 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/Filesystem/Filesystem.php(108): Illuminate\\Filesystem\\Filesystem::Illuminate\\Filesystem\\{closure}()
#10 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/View/Engines/PhpEngine.php(58): Illuminate\\Filesystem\\Filesystem->getRequire('/home/carlosmen...', Array)
#11 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/View/Engines/CompilerEngine.php(61): Illuminate\\View\\Engines\\PhpEngine->evaluatePath('/home/carlosmen...', Array)
#12 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/View/View.php(139): Illuminate\\View\\Engines\\CompilerEngine->get('/home/carlosmen...', Array)
#13 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/View/View.php(122): Illuminate\\View\\View->getContents()
#14 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/View/View.php(91): Illuminate\\View\\View->renderContents()
#15 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/Http/Response.php(69): Illuminate\\View\\View->render()
#16 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/Http/Response.php(35): Illuminate\\Http\\Response->setContent(Object(Illuminate\\View\\View))
#17 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/Routing/ResponseFactory.php(55): Illuminate\\Http\\Response->__construct(Object(Illuminate\\View\\View), 500, Array)
#18 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/Routing/ResponseFactory.php(85): Illuminate\\Routing\\ResponseFactory->make(Object(Illuminate\\View\\View), 500, Array)
#19 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/Foundation/Exceptions/Handler.php(585): Illuminate\\Routing\\ResponseFactory->view('errors::500', Array, 500, Array)
#20 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/Foundation/Exceptions/Handler.php(490): Illuminate\\Foundation\\Exceptions\\Handler->renderHttpException(Object(Symfony\\Component\\HttpKernel\\Exception\\HttpException))
#21 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/Foundation/Exceptions/Handler.php(356): Illuminate\\Foundation\\Exceptions\\Handler->prepareResponse(Object(Illuminate\\Http\\Request), Object(Symfony\\Component\\HttpKernel\\Exception\\HttpException))
#22 /home/carlosmendiola/public_html/facturacion/app/Exceptions/Handler.php(207): Illuminate\\Foundation\\Exceptions\\Handler->render(Object(Illuminate\\Http\\Request), Object(Error))
#23 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(427): App\\Exceptions\\Handler->render(Object(Illuminate\\Http\\Request), Object(Error))
#24 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(115): Illuminate\\Foundation\\Http\\Kernel->renderException(Object(Illuminate\\Http\\Request), Object(Error))
#25 /home/carlosmendiola/public_html/facturacion/public/index.php(57): Illuminate\\Foundation\\Http\\Kernel->handle(Object(Illuminate\\Http\\Request))
#26 {main}
[previous exception] [object] (ReflectionException(code: -1): Class translator does not exist at /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/Container/Container.php:877)
#0 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/Container/Container.php(877): ReflectionClass->__construct('translator')
#1 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/Container/Container.php(758): Illuminate\\Container\\Container->build('translator')
#2 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/Foundation/Application.php(851): Illuminate\\Container\\Container->resolve('translator', Array, true)
#3 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/Container/Container.php(694): Illuminate\\Foundation\\Application->resolve('translator', Array)
#4 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/Foundation/Application.php(836): Illuminate\\Container\\Container->make('translator', Array)
#5 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/Foundation/helpers.php(119): Illuminate\\Foundation\\Application->make('translator', Array)
#6 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/Foundation/helpers.php(835): app('translator')
#7 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/Foundation/helpers.php(870): trans('Server Error', Array, NULL)
#8 /home/carlosmendiola/public_html/facturacion/storage/framework/views/7972fc35c34c342be6e51c48b6ccc04a0f0fc3a8.php(1): __('Server Error')
#9 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/Filesystem/Filesystem.php(107): require('/home/carlosmen...')
#10 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/Filesystem/Filesystem.php(108): Illuminate\\Filesystem\\Filesystem::Illuminate\\Filesystem\\{closure}()
#11 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/View/Engines/PhpEngine.php(58): Illuminate\\Filesystem\\Filesystem->getRequire('/home/carlosmen...', Array)
#12 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/View/Engines/CompilerEngine.php(61): Illuminate\\View\\Engines\\PhpEngine->evaluatePath('/home/carlosmen...', Array)
#13 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/View/View.php(139): Illuminate\\View\\Engines\\CompilerEngine->get('/home/carlosmen...', Array)
#14 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/View/View.php(122): Illuminate\\View\\View->getContents()
#15 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/View/View.php(91): Illuminate\\View\\View->renderContents()
#16 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/Http/Response.php(69): Illuminate\\View\\View->render()
#17 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/Http/Response.php(35): Illuminate\\Http\\Response->setContent(Object(Illuminate\\View\\View))
#18 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/Routing/ResponseFactory.php(55): Illuminate\\Http\\Response->__construct(Object(Illuminate\\View\\View), 500, Array)
#19 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/Routing/ResponseFactory.php(85): Illuminate\\Routing\\ResponseFactory->make(Object(Illuminate\\View\\View), 500, Array)
#20 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/Foundation/Exceptions/Handler.php(585): Illuminate\\Routing\\ResponseFactory->view('errors::500', Array, 500, Array)
#21 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/Foundation/Exceptions/Handler.php(490): Illuminate\\Foundation\\Exceptions\\Handler->renderHttpException(Object(Symfony\\Component\\HttpKernel\\Exception\\HttpException))
#22 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/Foundation/Exceptions/Handler.php(356): Illuminate\\Foundation\\Exceptions\\Handler->prepareResponse(Object(Illuminate\\Http\\Request), Object(Symfony\\Component\\HttpKernel\\Exception\\HttpException))
#23 /home/carlosmendiola/public_html/facturacion/app/Exceptions/Handler.php(207): Illuminate\\Foundation\\Exceptions\\Handler->render(Object(Illuminate\\Http\\Request), Object(Error))
#24 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(427): App\\Exceptions\\Handler->render(Object(Illuminate\\Http\\Request), Object(Error))
#25 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(115): Illuminate\\Foundation\\Http\\Kernel->renderException(Object(Illuminate\\Http\\Request), Object(Error))
#26 /home/carlosmendiola/public_html/facturacion/public/index.php(57): Illuminate\\Foundation\\Http\\Kernel->handle(Object(Illuminate\\Http\\Request))
#27 {main}
[2022-03-29 12:01:02] production.ERROR: Uncaught ReflectionException: Class translator does not exist in /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/Container/Container.php:877
Stack trace:
#1 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/Container/Container.php(758): Illuminate\Container\Container->build('translator')
#2 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/Foundation/Application.php(851): Illuminate\Container\Container->resolve('translator', Array, true)
#3 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/Container/Container.php(694): Illuminate\Foundation\Application->resolve('translator', Array)
#4 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/Foundation/Application.php(836): Illuminate\ {"exception":"[object] (Symfony\\Component\\ErrorHandler\\Error\\FatalError(code: 0): Uncaught ReflectionException: Class translator does not exist in /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/Container/Container.php:877
Stack trace:
#4 /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/Foundation/Application.php(836): Illuminate\\ at /home/carlosmendiola/public_html/facturacion/vendor/laravel/framework/src/Illuminate/Container/Container.php:879)
#0 {main}
It may help to delete the bootstrap/cache folder
