I know this is a really nube question but I had disabled editing of previously created invoices.
I now can’t find the setting to re-enable this feature…can you please tell me where it is??
I’m assuming you’re logging in as a secondary user, as administrators can always edit invoices.
You’ll need to go to User Management and re-enable the edit permission for whichever user you want to be able to edit invoices.
When we try and save a previously sent invoice there is no SAVE button when there used to be?
I have full permissions. I recall reading an option where you can disable editing of previously entered invoices so that it can’t be tampered with. Am I correct?
Is this what you’re referring to:
https://invoice-ninja.readthedocs.io/en/latest/configure.html#lock-invoices
YES!!
That’s exactly what I meant…I had forgotten how/where I enabled it.
Thank you very much
