Think I found the possible issue! Could the email not send if there’s a permissions failure that is causing the the raw PDF to not generate? It looks like the email sending is part of that stack…
This error is the last one in my failed_jobs table.
Payload:
{“uuid”:“97fd26c0-ff9e-44f6-b6a3-bfd674962f8e”,“displayName”:“App\Services\Email\Email”,“job”:“Illuminate\Queue\CallQueuedHandler@call”,“maxTries”:4,“maxExceptions”:null,“failOnTimeout”:false,“backoff”:“27,55,70,271”,“timeout”:null,“retryUntil”:null,“data”:{“commandName”:“App\Services\Email\Email”,“command”:“O:24:"App\Services\Email\Email":2:{s:12:"email_object";O:30:"App\Services\Email\EmailObject":35:{s:2:"to";a:0:{}s:4:"from";N;s:8:"reply_to";a:0:{}s:2:"cc";a:1:{i:0;O:33:"Illuminate\Mail\Mailables\Address":2:{s:7:"address";s:23:"[email protected]";s:4:"name";N;}}s:3:"bcc";a:0:{}s:7:"subject";N;s:4:"body";s:163:"
Dear $client,
An Invoice has been generated. To view your invoice for $amount, please click the link below.
Thank you!</p>\n
$view_button</div>";s:9:"text_body";s:0:"";s:11:"attachments";a:0:{}s:8:"settings";N;s:10:"whitelabel";b:0;s:4:"logo";N;s:9:"signature";N;s:8:"greeting";N;s:13:"invitation_id";i:2683;s:9:"entity_id";i:1658;s:9:"client_id";i:28;s:9:"vendor_id";N;s:7:"user_id";N;s:17:"client_contact_id";N;s:17:"vendor_contact_id";N;s:19:"email_template_body";s:22:"email_template_invoice";s:22:"email_template_subject";s:21:"email_subject_invoice";s:13:"html_template";N;s:13:"text_template";s:19:"email.template.text";s:7:"headers";a:0:{}s:12:"entity_class";s:18:"App\Models\Invoice";s:9:"variables";a:0:{}s:8:"override";b:0;s:14:"invitation_key";N;s:9:"documents";a:0:{}s:8:"template";s:22:"email_template_invoice";s:5:"links";a:0:{}s:6:"button";N;s:3:"url";N;}s:7:"company";O:45:"Illuminate\Contracts\Database\ModelIdentifier":5:{s:5:"class";s:18:"App\Models\Company";s:2:"id";i:1;s:9:"relations";a:0:{}s:10:"connection";s:5:"mysql";s:15:"collectionClass";N;}}”},“sentry_baggage_data”:“sentry-trace_id=276b387ca3144dde831b9302f1bb6bb1,sentry-public_key=39389664f3f14969b4c43dadda00a40b,sentry-release=5.10.62,sentry-environment=production”,“sentry_trace_parent_data”:“276b387ca3144dde831b9302f1bb6bb1-dff706e8b1e142d1”,“sentry_publish_time”:1741200565.897787,“db”:“mysql”}
Exception:
App\Exceptions\FilePermissionsFailure: Unable to generate the raw PDF in /var/www/app/app/Jobs/Entity/CreateRawPdf.php:115
Stack trace:
#0 /var/www/app/app/Services/Email/EmailDefaults.php(311): App\Jobs\Entity\CreateRawPdf->handle()
#1 /var/www/app/app/Services/Email/EmailDefaults.php(77): App\Services\Email\EmailDefaults->setAttachments()
#2 /var/www/app/app/Services/Email/Email.php(234): App\Services\Email\EmailDefaults->run()
#3 /var/www/app/app/Services/Email/Email.php(109): App\Services\Email\Email->setDefaults()
#4 /var/www/app/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(36): App\Services\Email\Email->handle()
#5 /var/www/app/vendor/laravel/framework/src/Illuminate/Container/Util.php(43): Illuminate\Container\BoundMethod::Illuminate\Container{closure}()
#6 /var/www/app/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(95): Illuminate\Container\Util::unwrapIfClosure(Object(Closure))
#7 /var/www/app/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(35): Illuminate\Container\BoundMethod::callBoundMethod(Object(Illuminate\Foundation\Application), Array, Object(Closure))
#8 /var/www/app/vendor/laravel/framework/src/Illuminate/Container/Container.php(694): Illuminate\Container\BoundMethod::call(Object(Illuminate\Foundation\Application), Array, Array, NULL)
#9 /var/www/app/vendor/laravel/framework/src/Illuminate/Bus/Dispatcher.php(126): Illuminate\Container\Container->call(Array)
#10 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(144): Illuminate\Bus\Dispatcher->Illuminate\Bus{closure}(Object(App\Services\Email\Email))
#11 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(119): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline{closure}(Object(App\Services\Email\Email))
#12 /var/www/app/vendor/laravel/framework/src/Illuminate/Bus/Dispatcher.php(130): Illuminate\Pipeline\Pipeline->then(Object(Closure))
#13 /var/www/app/vendor/laravel/framework/src/Illuminate/Queue/CallQueuedHandler.php(124): Illuminate\Bus\Dispatcher->dispatchNow(Object(App\Services\Email\Email), false)
#14 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(144): Illuminate\Queue\CallQueuedHandler->Illuminate\Queue{closure}(Object(App\Services\Email\Email))
#15 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(119): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline{closure}(Object(App\Services\Email\Email))
#16 /var/www/app/vendor/laravel/framework/src/Illuminate/Queue/CallQueuedHandler.php(123): Illuminate\Pipeline\Pipeline->then(Object(Closure))
#17 /var/www/app/vendor/laravel/framework/src/Illuminate/Queue/CallQueuedHandler.php(71): Illuminate\Queue\CallQueuedHandler->dispatchThroughMiddleware(Object(Illuminate\Queue\Jobs\DatabaseJob), Object(App\Services\Email\Email))
#18 /var/www/app/vendor/laravel/framework/src/Illuminate/Queue/Jobs/Job.php(102): Illuminate\Queue\CallQueuedHandler->call(Object(Illuminate\Queue\Jobs\DatabaseJob), Array)
#19 /var/www/app/vendor/laravel/framework/src/Illuminate/Queue/Worker.php(441): Illuminate\Queue\Jobs\Job->fire()
#20 /var/www/app/vendor/laravel/framework/src/Illuminate/Queue/Worker.php(391): Illuminate\Queue\Worker->process(‘database’, Object(Illuminate\Queue\Jobs\DatabaseJob), Object(Illuminate\Queue\WorkerOptions))
#21 /var/www/app/vendor/laravel/framework/src/Illuminate/Queue/Worker.php(178): Illuminate\Queue\Worker->runJob(Object(Illuminate\Queue\Jobs\DatabaseJob), ‘database’, Object(Illuminate\Queue\WorkerOptions))
#22 /var/www/app/vendor/laravel/framework/src/Illuminate/Queue/Console/WorkCommand.php(148): Illuminate\Queue\Worker->daemon(‘database’, ‘default’, Object(Illuminate\Queue\WorkerOptions))
#23 /var/www/app/vendor/laravel/framework/src/Illuminate/Queue/Console/WorkCommand.php(131): Illuminate\Queue\Console\WorkCommand->runWorker(‘database’, ‘default’)
#24 /var/www/app/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(36): Illuminate\Queue\Console\WorkCommand->handle()
#25 /var/www/app/vendor/laravel/framework/src/Illuminate/Container/Util.php(43): Illuminate\Container\BoundMethod::Illuminate\Container{closure}()
#26 /var/www/app/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(95): Illuminate\Container\Util::unwrapIfClosure(Object(Closure))
#27 /var/www/app/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(35): Illuminate\Container\BoundMethod::callBoundMethod(Object(Illuminate\Foundation\Application), Array, Object(Closure))
#28 /var/www/app/vendor/laravel/framework/src/Illuminate/Container/Container.php(694): Illuminate\Container\BoundMethod::call(Object(Illuminate\Foundation\Application), Array, Array, NULL)
#29 /var/www/app/vendor/laravel/framework/src/Illuminate/Console/Command.php(213): Illuminate\Container\Container->call(Array)
#30 /var/www/app/vendor/symfony/console/Command/Command.php(279): Illuminate\Console\Command->execute(Object(Symfony\Component\Console\Input\ArgvInput), Object(Illuminate\Console\OutputStyle))
#31 /var/www/app/vendor/laravel/framework/src/Illuminate/Console/Command.php(182): Symfony\Component\Console\Command\Command->run(Object(Symfony\Component\Console\Input\ArgvInput), Object(Illuminate\Console\OutputStyle))
#32 /var/www/app/vendor/symfony/console/Application.php(1094): Illuminate\Console\Command->run(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#33 /var/www/app/vendor/symfony/console/Application.php(342): Symfony\Component\Console\Application->doRunCommand(Object(Illuminate\Queue\Console\WorkCommand), Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#34 /var/www/app/vendor/symfony/console/Application.php(193): Symfony\Component\Console\Application->doRun(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#35 /var/www/app/vendor/laravel/framework/src/Illuminate/Foundation/Console/Kernel.php(197): Symfony\Component\Console\Application->run(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#36 /var/www/app/artisan(35): Illuminate\Foundation\Console\Kernel->handle(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#37 {main}
