Hello, (Self-Hosted)
Please assist asap, each an every time when I’m sending out invoices or quotes I’m getting the following triangle exclamation mark below and my clients are not receiving any quotes or invoices that are sent. Please check an error below
“Address in mailbox given [] does not comply with RFC 2822, 3.6.2.”
Okay, on System Settings under Database Connection test connection [success], System Setting under Email settings from name, from address, username, host, port 587, encryption TLS, and password are all empty. Should I fill the form? if so please indicate where can I get a password, from name, from address, username, host, port 587 should I leave it or change it ?
