I apologies for the repeated question asked by many users.
I have updated .env as per below. Still emails are not working. Anything I am missing? I am not a developer. Basically a network Engineer. emails are different, I just masked it.
Thanks for your response. I will have a look in to this and get back to you. Once this is success, I would need help from you to whitelist the product. I will confirm once the payment is done. I am worried if I get any issue there…
Anyway all of these didnt help me to fix user email. I have directly entered in to user field of my php admin and marked as email verified with value “1” and did a work around. Now I have another weird issue that pdf preview is not opening while designing the invoice as well as creating new invoice.
platform exception(error, promise was rejected with a value of ‘undefined’. null, null
I am going to purchase white list license for two products. I hope you will give an extended hand to fix it.
I have tried almost all versions available in my hostinger.com platform and found 4.5.47 as stable one.
My issues currently.
No email invitation going. I am using IMAP emails. Tried to edit php and fixed as work around.
PDF preview not working while designing/creating invoice.
I am not a software developer, So my coding knowledge is very limited. I am basically an IT Networking and Security Engineer I was using VTiger till March End and trying to switch to Ninja.
I am basically going to buy two licenses, One for IT and one for Real estate. Both Invoice product field should be different.
Also the field columns should have VAT 5% (I Managed to add), Next- “VAT amount” on unit cost, Line total should be “Unitcost+vat amount”
I would be very grateful if you can extend your support. This is the mandatory requirement from the Federal Tax authority of UAE.
