Email not working (SMTP)
My emails don’t seem to be being sent. After i updated ENV from Database to QUEUE_CONNECTION=sync then it worked. Any solution to make email work with database?
You may need to add the queue:work cron to process the jobs in the queue.
Do you mean this cron
php artisan schedule:run >> /dev/null 2>&1
When i run it manually it didnt send the email either…
Please review the docs linked above, if you enable the queue you need to add the queue:work cron.
I get this error
In Worker.php line 718:
Call to undefined function Illuminate\Queue\pcntl_signal()
Maybe this will help:
https://laracasts.com/discuss/channels/laravel/call-to-undefined-function-illuminatequeuepcntl-signal
Already have it installed so not sure why its an issue. Any other solutions?
@hillel in my php.ini
disable_functions = pcntl_alarm,pcntl_fork,pcntl_waitpid,pcntl_wait,pcntl_wifexited,pcntl_wifstopped,pcntl_wifsignaled,pcntl_wifcontinued,pcntl_wexitstatus,pcntl_wtermsig,pcntl_wstopsig,pcntl_signal,pcntl_signal_dispatch,pcntl_get_last_error,pcntl_strerror,pcntl_sigprocmask,pcntl_sigwaitinfo,pcntl_sigtimedwait,pcntl_exec,pcntl_getpriority,pcntl_setpriority,exec,system,passthru,shell_exec,popen
Anything to do with this?
Seems likely, like the function you need is disabled.
So there so many pcntl do you know which one i should remove from disabled?
I suggest starting with pcntl_signal
